Kompresor mechov
Napsal: 20 pro 2011 09:18
od edgarius
Diskoteka je prerobena na pruziny, da sa nejak uzitocne vyuzit kompresor mechov? Kompresor by mal davat tlak 120psi (8bar), takze by sa dal vyuzit napr. na dofukovanie kolies. Robil to z vas niekto?
Re: Kompresor mechov
Napsal: 20 pro 2011 15:30
od RudaK
edgarius píše:Diskoteka je prerobena na pruziny, da sa nejak uzitocne vyuzit kompresor mechov? Kompresor by mal davat tlak 120psi (8bar), takze by sa dal vyuzit napr. na dofukovanie kolies. Robil to z vas niekto?
No D II nemám,ale si myslím,že na dofukování kol to nebude :Sorry: ( kompresor není stavěn na tak velký objem,jako je v kole - podle mě by nenafoukal ani to jedno kolo :ty jeden...: )
Napsal: 20 pro 2011 15:55
od Acon
možno, že príležitostne dofúkať zvládne, ale na dlho nie. Je stavaný len na pár sekundové cykly. Podľa mňa sa prehreje a zadrie. Ale skús, aspoň budeme vedieť :wink: Niekto musí byť 1. :yes
Napsal: 20 pro 2011 16:27
od edgarius
"The RR air compressor has been criticized by some for being inadequate in capacity and too expensive, but in reality it is a sturdy industrial 1/5 horsepower 20 amp "Wobl" piston unit made by Thomas Pumps, one of the best-known manufacturers in the world. It is a member of the Thomas Pumps 315 model series (see details below), has a flow rate of about 0.96 cfm at low pressure, and according to justcompressor.com (http://www.justaimli...ssor_thomas.htm" onclick="window.open(this.href);return false;) it can fill a 3 gallon tank from 0 to 150 psi in 4 minutes 45 seconds. It is commonly used by low rider fans to pump up their vehicles. It has to keep the 10 liter (2.5 gallon) Range Rover air tank charged up to 10 bar (150 psi), which is a much higher pressure than most off-road air compressers can reach. The compressor also has a much harder life than the average air compressor, having to operate in hot under-the-hood conditions (it is rated at 158 degrees ambient) for hundreds of hours rather than a few minutes at a time. "
http://forums.lr4x4.com/index.php?showtopic=6470
Tuto to chlapci rozoberaju. Len keby som mal vyhrievanu velku garaz a mesiac plateneho volna :angel
Napsal: 09 led 2012 18:45
od Jimmy discovery
Zdravím jsem tu nový a mam discovery 99 td5 a mam problém se vzduchem po zastavení me po chvilce ujde a je k jedné straně nevite nekdo co stim??? v terení poloze (uplně nahore to neudělá)
Napsal: 09 led 2012 19:42
od Acon
skoro určite deravý mech. V bežnej polohe je práve v mieste úniku prehnutý a preto vyfučí. Vymeň oba a budeš mať ďalších 12r. pokoj. Hlavne to vymeň rýchlo, lebo takto odpáliš kompresor. Aspoň tak si pamätám na rady znalcov.
Napsal: 09 led 2012 23:07
od vladob8
Mozem potvrdit slova Acona, mal som presne to iste, nasledovala vymena mechov a odvtedy pokoj. :party
Napsal: 15 led 2012 11:52
od Jimmy discovery
Děkuji mnohokráte :hand
Napsal: 15 led 2012 12:36
od Jimmy discovery
Zdravím jestě jedna otázka z mnoha: jaké měchy doporučujete?? koukal jsem že se dá sehnat pár za 6tis cca
a také pár za 18tis nevidím v tom žádný rozdil (KROM PENĚZ:-D)
Napsal: 15 led 2012 13:49
od masar
Jimmy discovery píše:Zdravím jestě jedna otázka z mnoha: jaké měchy doporučujete?? koukal jsem že se dá sehnat pár za 6tis cca
Nejlevnější bývá tzv. "Náhrada". na konci obj. čísla nejsou žádná písmena
Pak jsou díly dodávané do výroby ozn. jako "OEM" (u měchů třeba Dunlop), na konci obj. čísla bývá "G"
No a nakonec originál s ozn. "GEN", často (nevím jak u měchů) to bývá OEM díly v krabici s logem LR, na konci obj. čísla bývá "GEN"
Tady to máš vidět: http://www.litep4x4.cz/detail/discovery ... 200---mech" onclick="window.open(this.href);return false; http://land-rover.eliott.in/cz/e-shop/2 ... 1200g.html" onclick="window.open(this.href);return false;
