RR L322 párování dálkového
vladaz
auto: SIIA,DIII,L322,..
#1 Příspěvek od vladaz » 12 lis 2013 20:16
Ahoj, při jednom opravdu velmi hlubokém vybití akumulátoru mi u L322 přestal reagovat centrál na dálku. Klíčkem jde auto normálně nastartovat, ale nejde dálkově odemknout a zamknout. Zkusil jsem tady na fóru popsané fígle pro párování (sice platné většinou pro R38), ale bez úspěchu. Neměl by někdo radu?
Re: RR L322 párování dálkového
#2 Příspěvek od Kokesek » 13 lis 2013 07:43
Reset Procedure for your key fobs
Every signal from the remote handset contains the transmitter identification code and a rolling code. The BCU checks
the codes and only responds if the signal is from a valid transmitter. During vehicle production, the remote handsets
supplied with the vehicle are initialised to set their individual transmitter identification codes and synchronise their
respective rolling codes with the BCU. If a transmitter loses synchronisation with the BCU, or if a replacement or
additional remote handset is to be used with the vehicle, the initialisation procedure must be repeated. During the
procedure, all remote handsets for use with the vehicle must be initialised.
Initialisation Procedure
1 Ensure the vehicle is unlocked and the driver and front passenger doors are closed.
2 Install a key/remote handset in the ignition switch, then turn the ignition switch to position I and back to position
0 in less than 5 seconds to put the BCU into the initialisation mode. Continue the procedure within 30 seconds
of turning the ignition switch to position 0.
3 Remove the key/remote handset from the ignition switch.
4 Press and hold the unlock button for a maximum of 15 seconds. During this time, momentarily press the lock
button three times within 10 seconds.
5 Release both buttons.
6 Successful initialisation is indicated by the BCU locking then unlocking the vehicle. If this does not occur, repeat
step 4.
7 Repeat steps 4 and 5 with all other remote handsets belonging to the vehicle (4 maximum). Begin the
initialisation of each remote handset within 30 seconds of completing the previous initialisation, or the BCU will
drop out of the initialisation mode and the complete procedure will have to be started again.
vladaz
#3 Příspěvek od vladaz » 13 lis 2013 09:12
Díky moc, dobrá duše. Postup funguje, na první pokus OK. Odkud ten postup je? Nenašel jsem ho v servisním manuálu...
Ještě jednou moc děkuji!
#4 Příspěvek od Kokesek » 14 lis 2013 20:17
origo z UK LR
vladaz
#5 Příspěvek od vladaz » 14 lis 2013 20:21
:yes
Maxsel
#6 Příspěvek od Maxsel » 20 srp 2017 19:54
Postup funguje. :yes
Ještě bych měl otázku, kolik klíčů bylo originál k RR L322 2002 - 2006 (verze klíče BMW) ? Dostal jsem k autu 3ks, ale třetí klíč nefunguje. Tedy nejde ani spárovat dálka, ani s ním auto nejde nastartovat (IMO čip uvnitř je).
Discovery 4 TDV6 HSE
Discovery 2 TD5
