Chladiaca zmes
Chladiaca zmes
Po tyzdni som zistil, ze sa mi trati chladiaca zmes, ale len pocas prevadzky ked motor stoji chladiaca zmes neunika moze to byt tesnenie pod hlavou ?, auto topi a teplota drzi, ani tlak v nadrzke neni , neviete mi poradit? Vdaka vsetkym za rady.
ANO MUZE TO BYT TESNENI POD HLAVOU.ODSROUBUJ VICKO PRO DOLITI OLEJE A PODIVEJ SE NA JEHO SPODEK.POKUD TAM NAJDES SVETLE SEDOU EMULZY JE TO SPATNY.DALE SE TAKE PODIVEJ VZADU JAK JE VYFUKOVA SBERNA UVIDIS TAM TAKOVEJ VALECEK A VEDOU DO NEJ DVE VODNI HADICE.VNEM KDYZ HO VYMONTUJES UVIDIS NEKOLIK TRUBICEK.JELIKOZ JE KOLEM NICH CHLADICI SMES MUZE BYT PRICINA I TADY A TO DIKY TOMU ZE NEKTERA Z NICH JE PRASKLA.DALSI VEC JE VYMENIK V PREVODOVCE.VYPUSTIT OLEJ A POKUD MA JINOU BARVU NEZ JE STANDART A JE HO TAM VIC TAK I TU JE PROBLEM S VYMENIKEM JE PRASKLEJ.JE TOHO AZ MOC NA BOLENI HLAVY A HLAVNE SI NAPRED PROVER VESKERE SPOJE KAMA VODA PROUDI.
Libor píše:ANO MUZE TO BYT TESNENI POD HLAVOU.ODSROUBUJ VICKO PRO DOLITI OLEJE A PODIVEJ SE NA JEHO SPODEK.POKUD TAM NAJDES SVETLE SEDOU EMULZY JE TO SPATNY.DALE SE TAKE PODIVEJ VZADU JAK JE VYFUKOVA SBERNA UVIDIS TAM TAKOVEJ VALECEK A VEDOU DO NEJ DVE VODNI HADICE.VNEM KDYZ HO VYMONTUJES UVIDIS NEKOLIK TRUBICEK.JELIKOZ JE KOLEM NICH CHLADICI SMES MUZE BYT PRICINA I TADY A TO DIKY TOMU ZE NEKTERA Z NICH JE PRASKLA.DALSI VEC JE VYMENIK V PREVODOVCE.VYPUSTIT OLEJ A POKUD MA JINOU BARVU NEZ JE STANDART A JE HO TAM VIC TAK I TU JE PROBLEM S VYMENIKEM JE PRASKLEJ.JE TOHO AZ MOC NA BOLENI HLAVY A HLAVNE SI NAPRED PROVER VESKERE SPOJE KAMA VODA PROUDI.
NAJDI SI SUCHE MISTO MOTOR ZAHREJ NA PROVOZNI TEPLOTU A OPRAVDU SI RADNE PROHLIDNI VESKERE SPOJE A MRKNI DOLU POD AUTO JESTLI TI TAM NEKDE NA ZEM NEKAPE VODA.V PRIPADE ZE ANO PROVER TO TAK ZE TU KAPKU SI DEJ NA PRST A OLIZNI.BUDE TO SLEDKE A TIM VYLOUCIS ZE TO NENI OBYCEJNA VODA ALE CHLADICI SMES Z MOTORU.NEVES HLAVU NENI TO TAK HROZNE JAK TO VYPADA!
Tak teda neviem, zatka na olej cista, olej vprevodovke cisty, auto parkujem v garazi a pod motorom je sucho. Skusal som natlakovat nadobku ale nic som nezbadal. Vodu som mal na max, ked motor stoji pekne drzi, vcera som trochu s autom pojazdil a voda je na min, ak by to bol ten vymennik na vyfukovom potruby, tak by mi zmes unikala do vyfuku nie? alebo sa mylim?
Mam prislubenu knihu oprav na freelander, v CZ jazyku tak ju potom skusim naskenovat, a ak by mal niekto zajem rad sa podelim
To mas tak!Zasadni problem je v majiteli auta!nemyslim tim zrovna tebe ale celkove!Vsechno je to spotrebni material a jak kdo snim zachazi tak i schazi.Nevis kdo stim autem pred tebou co vyvadel a tezko se to i dozvis.Uz to ze malokdo za celou zivotnost motoru vymeni chladici kapalinu!Jinak tento typ motoru je konstrucne jednoduchy a zaradil bych ho do te poctivejsi starsi tridy.Neopliva na svuj obsach zadnym premrstenym vykonem na jedne strane je to ke skode ale co se tyce zivotnosti je to drzak.OVSEM JAK RIKAM KDYZ MU DAS CO JE POTREBA!!!Servisni intervali neprekracuj ba naopak!!!Snad ti k tomu neco napise i Admin.
- Admin
- Admin fóra
- tel.: +420 777 883 488
Častěji odchází těsnění pod hlavou na benzínech než na dieslových motorech. Tady by pomohlo zdiagnostikovat těsnost systému, ale tu si doma neuděláš.Karab píše:a ako to je tym tesnenim pod hlavou odchadzju na tychto motoroch?
Ještě bych zkontroloval jestli ti neutíká chladící směs přes výměník topení.
Mě se ted nedavno objevila pod plynovym pedalem kalužka modrozelené tekutiny. Měl jsem od toho špinavou i špičku boty. Nemůže to být onen únik z výměníku topení? Popř. kde hledat problém?Admin píše:Častěji odchází těsnění pod hlavou na benzínech než na dieslových motorech. Tady by pomohlo zdiagnostikovat těsnost systému, ale tu si doma neuděláš.Karab píše:a ako to je tym tesnenim pod hlavou odchadzju na tychto motoroch?
Mockrát díky
Re: vzmenik
mal som za to ze mi do nej unika kapalina, ale vcera som kontroloval olej a je cisti snad trochu tmavsi, ale ziadna emulzia a ani zvisena hladina, takze neviem kde sa mi ta zmes straca, ona mi unika strasne pomaly tak dva deci na tyžden, ale len ked jazdim ked auto stoji tak nic zeby tesnenie?Libor píše:ahoj co te k tomu vede?Neni to moc rozumne protoze tu prevodovku uvaris ale dej vedet proc to chces odpojit....
Re: vzmenik
AHOJ.PŘEČTI SI ZPRAVU DRUHOU ZHORA Z 1BŘEZNA CO JSEM TI K TOMU PSAL A POKUD SI ZTOHO NIC NESHLEDAL TAK TO NECH AŽ SE TO VICE PROJEVI.JINAK NEVIM JAK TI POMOC.Karab píše:mal som za to ze mi do nej unika kapalina, ale vcera som kontroloval olej a je cisti snad trochu tmavsi, ale ziadna emulzia a ani zvisena hladina, takze neviem kde sa mi ta zmes straca, ona mi unika strasne pomaly tak dva deci na tyžden, ale len ked jazdim ked auto stoji tak nic zeby tesnenie?Libor píše:ahoj co te k tomu vede?Neni to moc rozumne protoze tu prevodovku uvaris ale dej vedet proc to chces odpojit....
- majo2982
- tel.: +421908734538
- auto: RangeRover Sport S/C
Re:
Ten váleček nájdem aj na RRS 4,2SC?Libor píše: 01 bře 2007 10:01 ANO MUZE TO BYT TESNENI POD HLAVOU.ODSROUBUJ VICKO PRO DOLITI OLEJE A PODIVEJ SE NA JEHO SPODEK.POKUD TAM NAJDES SVETLE SEDOU EMULZY JE TO SPATNY.DALE SE TAKE PODIVEJ VZADU JAK JE VYFUKOVA SBERNA UVIDIS TAM TAKOVEJ VALECEK A VEDOU DO NEJ DVE VODNI HADICE.VNEM KDYZ HO VYMONTUJES UVIDIS NEKOLIK TRUBICEK.JELIKOZ JE KOLEM NICH CHLADICI SMES MUZE BYT PRICINA I TADY A TO DIKY TOMU ZE NEKTERA Z NICH JE PRASKLA.DALSI VEC JE VYMENIK V PREVODOVCE.VYPUSTIT OLEJ A POKUD MA JINOU BARVU NEZ JE STANDART A JE HO TAM VIC TAK I TU JE PROBLEM S VYMENIKEM JE PRASKLEJ.JE TOHO AZ MOC NA BOLENI HLAVY A HLAVNE SI NAPRED PROVER VESKERE SPOJE KAMA VODA PROUDI.
Mám podobný problém s vodou, ale nemám v oleji nič. Smrdí mi voda v expanzke od plynov.
